Building Haiku on Mac OS X 10.6 or 10.7 with Homebrew
The recommended method for building Haiku on Mac OS X is to use MacPorts, but, with a little bit of work it is possible to build Haiku using homebrew on Mac OS X 10.6 or 10.7 instead. You’ll need to install Xcode or at least the Command Line Tools before installing homebrew.
If you don’t want to install all of XCode you can install just gcc from the packages available here:
https://github.com/kennethreitz/osx-gcc-installer
Once you’ve installed gcc and homebrew installing most of the required software can be done with this command:
brew install autoconf automake gawk gnu-sed yasm wget libjpg
Optionally you can install cdrtools to build iso images with this command:
brew install cdrtools
There are a few formulas required by Haiku that are not included in homebrew including flex, bison, and gnu-regex. I have created formulas for these missing pieces of software.
bison:
require 'formula' class Bison < Formula url 'http://mirrors.xmission.com/gnu/bison/bison-2.5.tar.gz' homepage 'http://www.gnu.org/software/bison/manual/' md5 '687e1dcd29452789d34eaeea4c25abe4' version '2.5' def install system "./configure", "--disable-debug", "--disable-dependency-tracking", "--prefix=#{prefix}" system "make install" end def test system "bison --version" end end
flex:
require 'formula' class Flex < Formula url 'http://sourceforge.net/projects/flex/files/flex/flex-2.5.35/flex-2.5.35.tar.gz' homepage 'http://flex.sourceforge.net' md5 '201d3f38758d95436cbc64903386de0b' version '2.5.35' def install system "./configure", "--disable-debug", "--disable-dependency-tracking", "--prefix=#{prefix}", "--mandir=#{man}", "--infodir=#{info}" system "make install" end def test system "flex --version" end end
gnu-regex:
require 'formula' class GnuRegex < Formula homepage 'http://ftp.gnu.org/old-gnu/regex/' url 'http://ftp.gnu.org/old-gnu/regex/regex-0.12.tar.gz' sha256 'f36e2d8d56bf15054a850128fcb2f51807706a92d3bb4b37ceadd731535ce230' def install system "./configure" system "make subdirs=test all" system "mkdir -p #{prefix}/lib" system "libtool -lSystem -dynamic -install_name #{prefix}/lib/libgnuregex.dylib -o #{prefix}/lib/libgnuregex.dylib regex.o" system "mkdir -p #{prefix}/include" system "cp regex.h #{prefix}/include/gnuregex.h" end end
To install these formulas download them to rb files for instance flex.rb, bison.rb, and gnu-regex.rb and then use brew to install them by running:
brew install flex.rb brew install bison.rb brew install gnu-regex.rb
Haiku looks for gnu-regex.dylib in /opt/local/lib which is where MacPorts installs the file, but, homebrew installs it in /usr/local/lib/libgnuregex.dylib. No problem just create a symlink like this:
sudo mkdir /opt sudo mkdir /opt/local sudo mkdir /opt/local/lib sudo ln -s /usr/local/lib/libgnuregex.dylib /opt/local/lib/libgnuregex.dylib
Haiku also looks for gnuregex.h in /opt/local/include/gnuregex.h so make another symlink like this:
sudo mkdir /opt/local/include sudo ln -s /usr/local/include/gnuregex.h /opt/local/include/gnuregex.h
Once you’ve done this, you should be able to build the buildtools, install jam, and finally build Haiku!
