[GSoC 2023] Next up: Add reference images
I have fixed three memory leaks. Before, leak_analyser.sh found 75 leaks from simply opening and closing Icon-O-Matic. It now reports only 27.
I am now planning to implement a new shape type called “reference images”. This implements ticket #2748. As discussed in the ticket, having a reference image in the background greatly assists in vectorizing it. Reference images are just for reference. They will not be exported to the final HVIF file.
Zardshard's blog
- [GSoC 2024] Porting WebKit2 Final Report
- [GSoC 2024] Can I get discuss.haiku-os.org to work?
- [GSoC 2024] Implementing Mouse Support
- [GSoC 2024] Drawing to the Screen!
- [GSoC 2024] Fixing IPC in WebKit
- [GSoC 2024] Fixing the crashing
- Building WebKit Sensibly
- [GSoC 2024] Plans for Fixing Haiku's WebKit2 Port
- [GSoC 2023] Improving Icon-O-Matic Final Report
- [GSOC 2023] Progress on perspective transformation
